Old 01-17-2023, 11:01 AM
RoseHillFarmIHCC125 RoseHillFarmIHCC125 is offline
Default Xt3 gsx?
Is the XT3 GSX no longer available? That seemed like a nice mower, I liked the diff lock feature.
Old 01-17-2023, 12:26 PM
I believe it is gone. It's not on their site and I think I remember Sergeant saying it was not being produced IIRC.
It looks like the base tractor was around $6100 and I think the decks were another $1k. I don't see why a $7000 lawn mower didn't sell very well. Cub Cadet cannot compete in today's market so they stick with flooding the market at the big box stores.
https://greatwesternoutdoor.com/Lawn...f-ad7200877074
Old 01-17-2023, 03:07 PM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb
Shame.. This was the last vestige of the good traditional 2WD garden tractors associated with the Cub Cadet name.
These are arguably better bang for the buck than it's predecessors. The $7000 purchase price today equates to just over $2600 in 1986. You weren't going to buy an 1811 brand new for that money-not even close.
Of course, it's guys like me that are kinda to blame for the poor sales of these. Even though they are a good machine, I can't get over the looks of them, or the excessive use of plastic. I'm very content to use a mostly heavy steel 37 year old machine weekly, and have done so very reliably.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 01-17-2023, 05:03 PM
Ozcub's Avatar
Ozcub Ozcub is offline
Was that the last of the shaft drive mowers ?
How can they call it and sell a lawnmower without a deck , it is just a little tractor
Oz
Old 01-17-2023, 07:55 PM
Yeah man only shaft drive mowers left are the Deere 700 series. Simplicity doesn’t even make their Legacy series anymore. SCUT have displaced them altogether. Kinda sad.
Old 01-17-2023, 08:40 PM
Farmall450's Avatar
Anyone looking merely to mow their yard today would be best served with a ZTR. I do agree they're a bargain tho - a cyclops super was much more adjusted for inflation.
Old 01-19-2023, 10:49 PM
MSS7120's Avatar
MSS7120 MSS7120 is offline
The Kubota GR 2020G and GR 2120 are still available. Shaft drive with 4wd for about 10K Gasoline or 12k Diesel . At least per the web site.
Mark from Minnesota
3165 with CC Snow Blower, Front blade, Sims Cab
3185 with 3pt hitch, it runs now. But not well.
48in and 52in mower decks
2185 with mower from my dad when I have a project for it.
Massey Ferguson Model 70 corn planter.
CC yard cart
Old 01-20-2023, 03:11 AM
Sergeant's Avatar
Sergeant Sergeant is offline
The reason the XT3 GSX was dropped was actually do to parts availability starting in 2021. They started to have issues getting the Cast Iron Transmission cases, which were built in China. It was supposed to be dropped in 2022. But they decided to exhaust stock before dropping the machine, so it was continued for 2022. Since Mid-2022, you couldn't actually order one. It had to come from available dealer stock.
I was also told by a friend, an MTD territory man, the new parent Stanley, wants to push for more battery powered models in the near future. No need for a drive shaft model to be left in the production the XT1 & XT2 series frames. Hood design can be easily be converted to a battery powered machines. I really think Stanley is jumping the gun, as you can't wash or use their battery powered machines in wet weather.
Furthermore, I Like My 2018 XT3 GSX. The only downside I saw with the XT3 & 2011 and after 2000 series, was the change in the rear hitch plate design. So it couldn't accommodate the 2500 series Electric Lift sleeve Hitch or 30-inch Hydraulic tiller. It took MTD forever to even get an OEM sleeve hitch, that would fit the after 2011 2000 series. A OEM sleeve Hitch finally came out in late 2016.
The other issue with them, I thought, was the electric lift only, lifts the mowing decks and front snow/dozer blade. I think it should Have lifted the front OEM 46-inch blower as well. I really think they should have used an electric over Hydraulic actuator or even a Hydraulic cylinder. The electronic Power Steering is nice, but still not as nice as Hydraulic power steering. The Transmission is basically the same final drive, and case as the 3000 series but with a BDU10 Pump, instead of a BDU 21 pump the 3000 series used.
I have the following for My 2018 XT3 GSX
54-inch fabricated deck with OEM Mulch Kit.
46-inch OEM Front Blade.
OEM Front/rear weight bracket
OEM sleeve Hitch with Johnny Products Electric lift upgrade.
OEM Snow Cab (really just to try it out and had told others to buy the Original Cab for the 2011 2000 series and after) I should have followed my own and advice, as the Cab needs better lower front windows to see the edges of the OEM Snow/Dozer Blade.
30-inch Bercomac belt driven PTO tiller.
Plan to Buy the Bercomac Belt driven Rotary Broom for it eventually.
I still don't like the color scheme of the XT3 series.
I don't actually mow with it The XT3 GSX anymore. I started using a 2022 Cub SX54(steering wheel Zero turn) in April 2022, which I order In October 2021. Great Zero turn, which was also dropped for the 2023 Model Year.
RoseHillFarmIHCC125, if you still want a Cub Cadet Garden tractor with Diff/lock, there still is the XT2 GX54 D. Which I will say has been a great Garden Tractor. For a friend of ours, it has over 600 hrs on it. Probably more now, the wife & I bought it for him, in 2017.
Only issues he has Had with the XT2 GX54 D, seat replaced, and fender deck replaced, under warranty. His kid damaged the seat and did something to the fender deck, and Cub covered it under warranty.
Oil drain replacement, bad design on Kohler's part, replaced under warranty.
Not covered under warranty, and should have been covered.
Original snow blade fell apart after 1 winter use (dealer claimed to MTD he used it commercially). Bought the new designed fast attach all-season Plow Blade, which hasn't been an issue for him since.
0riginal, 60 RER, 70, 106, 1450, 2182, 3208, XT3GSX & SX54 Z Force
Old 01-20-2023, 03:21 AM
Sergeant's Avatar
Not a Garden tractor, just a over Priced Lawn Tractor. You could classify it as a Yard Tractor I suppose, with Hydraulic Lift & Power steering. No OEM Sleeve Hitch or 3 point Hitch available for it . When the GR first came out it, was notorious for steering control issues which were eventually fixed Later, in production, with a redesign. Now, it's known for transmission seal issues. The closest thing Kubota has to a Garden Tractor, would actually be the BX1880 Sub Compact, with 24X12 rear tires.
Old 01-20-2023, 06:40 AM
I didn’t know Stanley (Black & Decker) was the parent of MTD. Stanley is also the parent of Mac Tools.
