Old 05-02-2023, 12:40 PM
RC12345 RC12345 is offline
Default Trouble with CC 126
Hello,
I've been trying to keep the old family 126 going for years and I now have a problem that I'm not sure about. It's a 1971 gear drive that I replaced the clutch on about 10 years ago. What's happening now is when the tractor is off and in gear I can still push it. It doesn't push as easy as when it's in neutral but it still moves. Also, when running the wheels don't have much power.
I hope someone can help me out.
Rick
Old 05-02-2023, 12:50 PM
Check the whole clutch assembly for worn and/or broken parts and proper adjustment
The main spring may be broken.
The teaser spring may be broken as well.
Sounds like it's about time for a complete clutch and drivetrain inspection and overhaul if necessary
Any odd or unusual noises when depressing the clutch?
Old 05-03-2023, 12:55 PM
Default 126
The springs look fine. I put the tractor up on jack stands and it will run but the right wheel spins better than the left. The whole thing makes so much noise it's hard to tell where each sound is coming from.
I know the clutch release lever is worn and needs to be replaced.
Could this be something in the differential?
Tags
126, clutch, transmission
