Hello,
I tried to put belt on my mower deck on 1772 w/50C mower deck. The belt is B90 Gates, supposed to be the good one for this set up. Is too short all binder are in minimum position and mission maybe 3-4 inch to install the belt. Someone has this problem in the past? My mule linkage are OK ? see picture |
The correct belt for your application is a 954-3006, which is a Section B belt x 93".
a gates b90 is supposed to be 93'' and ok to replace 954-3006 but I dont know why, is to short
The OEM Part Number is correct for a 1772 w/50C (190-359-100) using a 190-361-100 Mule Drive, and that the Mule Drive and 50C deck are installed per OEM recommendations.
Is this a new purchase or have you owned the tractor for some time?
If not. You may want to download the 50c deck manual to check if it is mounted correctly.
Here is a link to the 50C Owners Manual.... Manual
First time I put the mower deck on the tractor
The 50C Mower Deck could have two different Mule Drives to operate the deck.
* 190-360-100 used on standard Garden Tractors * 190-361-100 used on Super Garden Tractors. The Mule Drive (or PTO) belt, varies with the Mule Drive being used. Mule Drive Belt: * 190-360-100 uses 954-3003A (Sec B x 89.5") * 190-361-100 uses 954-3006 (Sec B x 93")
