Old 10-14-2023, 11:19 PM
amos61 amos61 is offline
Default flywheel ring gear
i recently tried to repair a flywheel ring gear - it had a crack and would spin freely on the flywheel - i ground a taper on the ring gear - welded it and reformed it to original - i put flywheel in freezer and put the ring gear in my grill . after about 30 minutes i dropped the ring gear on the flywheel - it turned out perfect - and was proud - then after about an hour i noticed it had cracked again - not on repair area but elsewhere. any suggestions on what i should do?
Old 10-15-2023, 06:37 AM
What engine are you working on?
Old 10-15-2023, 11:20 PM
i am working on a sv600 - kohler courage 20 twin cam ohv
Old 10-16-2023, 05:09 PM
Your best bet is to buy a replacement flywheel.
Kohler 20-025-44-S flywheel
https://www.google.com/search?q=sv60...t=gws-wiz-serp
Used on E-Bay $70.00
https://www.ebay.com/itm/27606571954...RoCacUQAvD_BwE
Old 10-17-2023, 08:18 AM
ty sam - thinking the same thing just was hoping not to put alot into it
