Old 10-18-2023, 04:45 PM
gscott gscott is offline
Default Cub 73 Big Block Update
Just a quick update on the 73.
The k341 is still kickin butt...no issues...no burning oil.
I was having to replace front wheel bearing every season.
With a little research, I chose to install a wide frame front axle.
For some reason it steers like it has power steering now??
Additionally, I utilized a 5 lug front hub kit from extreme motorworks.
I also fabbed up a spring loaded idler pulley for the 36 cutting deck.
Only had to replace the v-belt 1 time in 3 cutting seasons (3 acres per cut)
Thanks for all the info you guys put on here...it really helps me.
Old 10-19-2023, 08:17 AM
jcubtroy's Avatar
jcubtroy jcubtroy is offline
Nice rod. good thinking in the build. i made mine just a yard machine, Reason price per cutting per season. 341 would push a 48" deck no problem.
