Old 03-25-2024, 10:39 PM
ChristopherCT ChristopherCT is offline
Unhappy mouse troubles and how to test carb behavior on K301, CC129
Hello Gang. Frustrating day here. I should have really cleaned out the 301 before today's attempted start bcz at both the front and rear of the engine mouse things happened. Much worse than previous years. I must try the dryer sheets method next winter...
After cleaning up the mouse, whose complete organ group was neatly separated from its elongated body, I proceeded to try to get the nest out of the flywheel area. This one was dense, and I got frustrated and tried to spin it out using the starter and an air compressor with a long air wand- stuck down almost touching the flywheel. No start. I finally got the nest completely out by hooking parts of it with a hooked gasket pick. I check spark- yes. I clean points. I change fuel filter and the very old hoses. I check the carb needle for flow through. No start. I notice that some head bolts are not very tight, so I open that up and give the mating surfaces a basic cleaning and put them back together with better torque. No start. Key then breaks off in ignition. Small screwdriver to the rescue.
This K301 ran fine when parked in November. So... the carb looks like an inexpensive non original one. Maybe I should change that after 5 years of use. Maybe it is not really sending fuel. Or maybe my spark is too small but it looks average to me. Maybe the points gap could be changed... Could the mouse nest and urine in the flwheel area have damaged something there? I "wants" to start, but wont even fire on spray. Thank you, helpful folks, for reading.
Old 03-25-2024, 10:49 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Compression? Sticking valve maybe?
Plow blade
#2 Cart
QA36 snowthower
Old 03-25-2024, 11:12 PM
While I had the head off, I spun the engine through its cycles. The valves rose and fell, were not loose and appeared okay to my amateur eye.
Old 03-26-2024, 08:28 AM
ironman's Avatar
ironman ironman is offline
You have a starter/generator, no alternator under the flywheel, so there is nothing that could be damaged in there.
When you say you "checked the carb needle for flow though", what do you mean?
Did you have the carb bowl off? Was there a powdery residue or other crap in the bowl?
Old 03-26-2024, 08:55 AM
jbrewer's Avatar
jbrewer jbrewer is offline
You say it won't fire "with spray"
If you squirt a little gas into the cylinder down the carb throat , will it fire?
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 03-26-2024, 09:06 AM
crazycubtrio crazycubtrio is offline
I’m thinking stuck needle and seat in carb not allowing fuel to flow into the bowl. With fuel valve on crack the bolt loose on the bowl and see if any drips out.
Old 03-26-2024, 01:06 PM
You folks are very helpful. Thank you for saying that there is nothing delicate at the bottom of the flywheel area. I have not exposed it yet, and I would like to avoid that.
When I say no start "with spray", I am talking about some ether into the body of the carb. I am using an ether with lubricant, I think it is 50%. It wont even really "pop" for 1 or two spins. The only hint of combustion/explosion sounds like 1/3 of what it needs to spin up to speed.
When I say I checked the carb needle for "flow through", I mean I gently poked it with a nylon bristle from a parts cleaning brush, I sprayed it with carb cleaner, and then with my mouth I found I could easily blow through the length of the needle and found that both tiny holes were clear.
Lastly, the float bowl does have some gas going to it for sure because it flows out when I removed it. A few years ago the float valve gave me some trouble but then became functional again. I think I should try a new carb. I should also remove last years fuel, although it did have stabilizer in it.
My new fuel line route is a little longer than the previous one. Maybe I have violated some plumbing principal of gravity fed carbs, but I don't think so. If anyone can send me a link to a photo of proper fuel lines on a K301, CC129, that would be great. There seems to be very little room for the in-line filter. Maybe I should buy a smaller filter too.
Old 03-26-2024, 04:34 PM
I believe there is a compression release function on the 301, is it spinning fast enough to build compression? how is your battery? I had a starter/generator go out (slowly) and it would not start as it had no compression due to the slow speed of the starter. once I got a new starter and realized how fast it is supposed to crank it starts right up.
Old 03-26-2024, 05:37 PM
jbrewer's Avatar
Did you squirt some actual gasoline in the carb throat (I like a hot dog mustard squeezer for this but you can dip some fuel line into a thing of gas then hold your thumb over the dry end ... put the wet end into the carb and release thumb)
This is a faster test than most ....
If it start and runs for 5-10 sec you can be sure it's a fuel issue (not compression release, valves, etc...)
...if it does then...
If you remove the fuel line from the carb end, does fuel run out?
If it does, it's a carb issue
These carbs are so simple, there's not much that can go wrong . If you CAREFULLY take the bowl off so as to not tear the gasket, if you clean the needle and seat and can blow from the seat to the gas inlet, then carefully reassemble, there's not a whole lot else that can go wrong.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 03-26-2024, 07:10 PM
Default success!! running!! phew.
Thanks everyone. Your comments and willingness to share helped me dive back in to the 129 today. As is often said- be methodical and check everything piece by piece.
I gave the somewhat drained battery some more charging time. Meanwhile I looked at that needle again and realized that it has maybe six holes in it. So I carefully cleared them and checked them. Then I ran the starter three times, about ten seconds each. I added more 50% ether spray (the kind with some lube in the mix) and FINALLY a few gentle bangs. Immediately a whole handful of moist debris and mouse bodies flew upwards out of the flywheel area. I will NOT be sharing pics of that. I truly believe that this hidden debris was probably slowing the crank speed to just below the rpm it needed.
After that, it was running like a champ, probably better than all of last year due to everything I tweaked. I drove out of the garage so distracted that I dragged the charger and extension cord with me.
So thank you, and now all is well. Time to use those dryer sheets or something. Mothballs did not work for me. I have included a few pics. (Yes, some parts are still off, including air cleaner, air shrouds, and exhaust supports.) And feel free to criticize my temporary fuel line. I think I need a smaller fuel filter.
Tags
k301, mice
