Old 05-14-2024, 11:40 AM
TomsCub129 TomsCub129 is offline
Default Blade leveling
Hello, I was wondering if anyone could tell me if there is a way to level the blades on a 44A deck so that the outer cutting edges are level with each other. On mine, there is about a 1/4" difference from the edge of the outer blade to the edge of the center blade. Can this be shimmed or is there an adjustment I can make? It does not cut evenly right now.
Old 05-14-2024, 07:35 PM
Ozcub's Avatar
Ozcub Ozcub is offline
Go to this page , enter your model details and it will show you the manual
https://www.cubcadet.com/en_US/conte...artstream.html
Oz
Old 05-15-2024, 05:11 AM
I had a newer deck from a 3000 series that was doing the same thing. I ended up having to shim the spindle housing to make them all on the same plane.
