Old 05-25-2024, 03:18 PM
CraiguS CraiguS is offline
Default Greetings from Gosh Durn North Carolina
Well met fellow travelers,
My name is Craig, I just picked up a 149. First Tractor, and already feel like I own two jeeps(If you own one you know what I mean). So far a lot of fun just tinkering with it. I've gotten a carriage, wide mule drive and a 50c deck that needs attachment so feel expect to many questions.
Heres a picture of my old boy and Bucko
https://photos.app.goo.gl/mC9sznoN1x5PgZMn9
Old 05-25-2024, 04:54 PM
CubDieselFan's Avatar
Welcome to Only Cub Cadets.
Old 05-25-2024, 07:53 PM
Your 50C deck will not work on a 149 as the 149 has a PTO w/a 3/8" pulley to match the 3/8" pullies used on the 44A and 50A decks.
The 44C and 50C decks use a 5/8" belt.
I wish you were closer as I could use a 50C deck and could swap w/you!
Old 05-25-2024, 09:24 PM
I was under the impression the wide mule drive would fit right up. well, the 400 mile road trip was nice nonetheless.
Old 05-25-2024, 09:58 PM
The wide frame mule drive probably will but the pullies are probably 5/8" as well for the 50C deck.
Did the seller tell you it would fit?
Old 05-26-2024, 01:31 PM
no he didnt work presumed they did. I got it at worst thinking i could just replace the pulleys where needed.
Old 05-26-2024, 03:52 PM
Well, that is a possibility.
Make sure you get the correct diameter pullies though.
I believe the A decks used smaller ones.
Old 05-27-2024, 03:30 PM
Ive got several projects going on right now, to the point my wife has noticed outback. That being said, im a couple of weeks I plan on replacing all the pulleys anyway. With this insight I'll make sure they all are of the same size, perferably 5/8" from the deck to the PTO.
craigus
Old 05-27-2024, 07:30 PM
Your PTO is the smaller 3/8" pulley.
You can't drive a C deck (5/8" pulley) with a 149 3/8" mechanical PTO which your 149 came equipped with.
Post some pictures of that mule drive, both ends, It may not even work even if you do swap to 3/8" pulleys.
Old 05-28-2024, 10:14 AM
jbrewer's Avatar
jbrewer jbrewer is offline
Welcome from another NC Cadet fan!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
