Old 11-16-2024, 01:35 PM
Shank 64 Shank 64 is offline
Default 105 1st & Reverse problem
Hi New to site,
I have a 105 that will not shift into 1st or reverse ? 2nd or third works fine.
very little movement. Has been sitting a while. rebuilt carb best i could. It will run with choke on. No air filter installed, need to find it? removed mower deck, seems to be in good shape. Should i try and mow with it? Ser. number is 105689 . Thanks for your help trying to figure out shift problems.
Kevin
Old 11-16-2024, 07:40 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Originally Posted by Shank 64 View Post
Hi New to site,
Kevin
105?? Unless the tractor been transgendered , the 105 is a hydrostatic.
Plow blade
#2 Cart
QA36 snowthower
Old 11-17-2024, 08:42 AM
Billy is correct but check these out. These are from the Technical Library Section on this site.
https://www.onlycubcadets.net/forum/...ead.php?t=4624
https://www.onlycubcadets.net/forum/...ead.php?t=4625
https://www.onlycubcadets.net/forum/...ead.php?t=4626
Old 11-17-2024, 11:52 AM
ironman's Avatar
ironman ironman is offline
Assuming it's not a 105, this post might help.....
https://www.onlycubcadets.net/forum/...14&postcount=4
Old 11-18-2024, 11:35 AM
jbrewer's Avatar
jbrewer jbrewer is offline
Hi New to site,
Kevin
If it is indeed a stick, if you take off the shifter plate the problem is likely staring back at you (the pawl on the rods in the transmission probably are broken, bent or loose on the Reverse and First shaft which should be on the right as you're looking down on it from the seat) . Should be an easy fix, but send a post a pic of you're stuck).
Carb should not need the choke to run if it's correct. Have you backed out both mixture screws 2 turns to start with?
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
