Old 01-26-2025, 04:59 PM
Default Picked up long ago
I have had this Original since 2008. It ran when I parked it. I remember when I picked this up the clutch was in need of some help.
It has been in storage all these years and it is time to get it running again.
It needs a few things, but the tank is clean, and the choke and throttle cables move freely.
Axle seals and the tranny needs a going over.
Carb clean but we will check to see it will start first.
Oil change.
See what is up with the clutch.
Remove that pesky creeper as it need to be gone over, over to my other Original.
Steering has some slop.
This and that and the other thing...
Up to 534 and counting...
Old 01-26-2025, 05:17 PM
twoton twoton is offline
Looks like a good winter project!
Old 01-26-2025, 05:23 PM
Ozcub's Avatar
Ozcub Ozcub is offline
Good to know you have sat back and thought about this project , no good rushing in thats when mistakes are made
Oz
Old 01-26-2025, 05:28 PM
Time to turn the heat on.
Old 01-28-2025, 05:39 PM
I put the heat on in the shack was able to do a little work on the "O" the last few days. Removed the dash tower as it was in bad shape, had some PO mods to it. Put all the parts from the old to the one I had laying around. Did a little rewiring to the harness and replaced the VR with a know working one I had laying around. Then I tackled the creeper removal. Simple way of removal, tip it on its side, no laying around! The flex coupler was a little worn and I can see why I was having issues with the clutch.
More updates in a few days...
Old 01-28-2025, 06:58 PM
CubDieselFan's Avatar
Nice work Lew.
Old 01-29-2025, 06:54 PM
Thank you, more updates later in the week...
Old 02-02-2025, 01:53 PM
Old 02-04-2025, 10:22 AM
I took the clutch apart, need a teaser and a thrust bearing, otherwise in needs nothing else.
Old 02-05-2025, 05:17 PM
More progress, clutch reassembled and installed. Put on the nicer dash tower and such...
Need a dash grommet for the steering tube.
Pix for Twoton to look at in his rocking chair as us old guys have them...
