Old 03-23-2025, 12:50 PM
David M David M is offline
Default Cub Cadet XT1 LT50 - Electrical problem ?
Howdy, I have a 2018 XT1 LT50 with a Kohler 7000 series 24 hp motor. While mowing, it stopped running. The starter will turn over the engine, but it will not run unless starter fluid or gas is externally placed in the carburator. I later found a fuel leak in the gas tank, and replacec everything from the gas tank to and including the carburator.
The headlights will only come on with the ignition in the "start" position. The headlights will not come on with the ignition in the "run 1" or "run 2" position. The battery is fully charged. The fuse is good. The Ignition has been replaced. I have performed an ohms test of the ignition switch, and confirmed it is working as per the specifications.
When measuring voltage at the ignition switch I have 12v to the Orange wire (S) on the switch at all times. When in start postion at the switch I have 9.7v to the red wire (B) & red wire (A1), and 7.8v to white wire (A2), 16.9v- 21v to yellow wire (M). With the ignition in Run 1 and Run 2 postion, there is only voltage to the orange wire (S).
The wire to the carburator has 9.7v in the start position only.
The spark plugs and magneto are gapped properly and clean.
If the relay beside the engine (HFV6 012ZS-TR) is unplugged, it still operates the same as with it plugged in. I am about to order a new relay, just to continue throwing parts at the problem.
The starter was destroyed, stuck in start position. I replaced the starter and solenoid.
Thank you in advance for any and all help and suggestions which will be
greatly appreciated.
Thanks for the suggestions. I found broken wires at the ignition plug, so I cut out the plug, and connected the wires to the back of the ignition. Everything works properly now.
Old 03-23-2025, 02:17 PM
ironman's Avatar
ironman ironman is online now
Seems to me you should have voltage to the carb with the key switch in the "start" AND ALSO in the the "run" position.
I would try running a hot jumper from the battery pos terminal to the carb solenoid and see if it starts.
Old 03-24-2025, 12:16 AM
Thank you, I will give that a try.
Old 03-24-2025, 09:29 AM
Road_Clam Road_Clam is offline
The relay near your starter , does that relay cycle "click" when you cycle the ignition off and on ?
Tags
cub cadet xt1 lt50", electrical problem
