Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Briggs & Stratton Engines
Old 06-11-2025, 08:34 AM
Justinp Justinp is offline
Default 1641 Carburetor issue.
I purchased and installed an aftermarket carb. This carb has come pre-set, and the adjustment screws have been plugged. The issue is keeping a constant rpm setting. Idle is fine but half throttle increases to full throttle. I also get occasionally backfire through the carb.
Would you have any suggestion to solve this issue?
Old 06-12-2025, 05:40 AM
The new China carbs are hit or miss if that's what you have. I've used 1 or 2 and had pretty good luck but lots of others have not. Do you still have the original carb? If so, I'd try to clean that one up and use it.
