Old 06-19-2025, 07:52 PM
ccpullin ccpullin is offline
Default H-3 Tripple Hydraulics Installed on 2182 Super
Well I did it! I installed Tripple Hydraulics (H-3) on 2 of my 6 2182 Supers! Upper valve is for RF hydraulics, center valve is for center lift and 3 point hitch and lower valve for LF hydraulics and rear hydraulics. At some point in time I want to install a separate cylinder for the 3 point hitch so the hitch does not go up and down with mower/blade/snow blower. Ended up being quite a challenge having issues such as pressure hydraulic line hitting steering tower, hole not large enough for all 3 valves in tower, 8 hoses to go around and under radiator... I removed dash although kept radiator in it and worked around it so I could make sure pressure line from power steering to lower valve did not touch radiator or mount (only 1/8" clearance around it) and to run all 8 lines clearing radiator. Time will tell if I install H-3 on the other 4 2182's but for right now I am very satisfied!!!
Have pictures of procedure if interested.
Old 06-20-2025, 08:42 AM
Great job and those Kubota gassers look very nice!
Old 06-20-2025, 08:44 PM
LarryW's Avatar
LarryW LarryW is offline
Wow! Very cool! Great idea!
Cub Cadet 147 2050041u340160
42" Mower Deck, Snow Thrower, Tire Chains and Weights, Rotary Tiller 1, Brinly Sleeve Hitch, Brinly 10" plow, Johnny Bucket Jr.,42" QA NF Dozer Blade.
Cub Cadet 1872 SGT
60" CCC deck.
Parts 129 future plans =ported pump for 147, cast iron rear for 1872,129 frame and steering axle= ?wagon?
