Old 06-25-2025, 03:49 PM
bob f bob f is offline
Default cub 147 hydro resistance
cub 147 hydro works fine in forward and reverse but have to hold the lever back to go slow. It always wants to work its way to full speed in both directions. Any ideas
Old 06-25-2025, 04:58 PM
Grandpa53 Grandpa53 is online now
You will need to adjust friction assembly or possibly replace friction assembly components at bottom of shifter shaft.
Old 07-01-2025, 05:26 PM
Removed the steering column and battery, the adjusting nut was easy to get at. It is a 1 1/16 nut. Works good now, the speed lever stays where I set it.
Old 07-01-2025, 05:44 PM
Thumbs up
? Pretty simple critters. Huh?
Tags
2 125's and 1 147
