Old 08-30-2025, 08:00 PM
John TV John TV is offline
Default I have a clunk!
So while repairing the Trunion spring which you folks helped me with, I dropped a few parts under the tractor and had to roll the tractor a few inches back and forth to retrieve the parts.
That’s when I noticed a rather significant “clunk” in the rear end. I could both feel it and hear it easily. I did not notice it when the tractor was running. The clunk seems to happen when first rolling the tractor forward or reverse a few inches. I jacked up the rear end and the clunk seems the same with no weight on the tires. I could not notice any wheel bearing movement when I tried to check each wheel individually. And the differential allowed the wheels to move as I believe they should when spun in different directions.
I realize that the next step is likely removing the rear plate and having a look. It I’m wondering if there are other tests I could do to give me direction in what to look for when I do the inspection?
I will attempt to upload a short vid that shows the problem. I appreciate any assistance or direction you can give me.
John in Minnesota
My attempt to upload vid did not work.. need to figure out how that works too!
Old 08-30-2025, 08:24 PM
green407's Avatar
green407 green407 is offline
Sorry to say, but a "clunk" is a very vague complaint.
We'll have to wait for the movie for a better understanding.
But most likely I would think it's excessive back lash between the ring and pinion gear. Which for what these machines do isn't harmful.
Glad you got the trunion fixed
128 X 2, 129, 149, 1250, 1450 x 2
Old 08-31-2025, 07:42 PM
Default Maybe a video link?
I may be technology challenged cuz I can’t seem to get this link properly in this post but there is a short YouTube of the clunk I’m talking about.
I agree, clunk is way to vague to get and response. Just having trouble getting vid up.
Link should be:
https://youtube.com/shorts/J505cyqyA...GXb0_0A6WUSCFR
Not sure what I am doing wrong with link.
John in Mn
Old 08-31-2025, 07:47 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Google "how to change private video to public in YouTube" That might help
Plow blade
#2 Cart
QA36 snowthower
Old 09-02-2025, 09:32 PM
dale c. dale c. is offline
maybe a broken ring gear housing ? time to pull the cover for a look.
Old 09-08-2025, 01:04 AM
Thanks Dale,
Yes I think I need to take the cover off soon. I had to adjust the trunion the other day and had the tractor running for a short time. With the motor running I cannot notice the clunk, or feel it. I don’t want to be too aggressive in changing directions until I have a better sense of what the clunk might be. I cannot get to opening up the diff until October sometime. Time to order a new gasket etc.
Thanks for your thoughts.
John in Mn
