Hello,
I attempted to search for this topic but was unable to find anything. I have an older LT1050 with 490 hours (model number 13RQ11CP056), it has the Kohler Courage 25 engine. Last week it started to run rough when hot and under load. I diagnosed it as the coil on the right side. I bought a set of after market coils. That fixed the power issue, but now I have a LCD Display issue. When the key is turned on, I get the battery voltage for a few seconds then the hours show up like usual. After starting the engine, the LCD display starts to flicker with different characters and the Batt light on the display will have a random flicker as well. I tried another new set of coils (different brand) with the same issue. Has anyone experienced this? If so, is there a solution. Thanks in advance for your help. |
| Tags |
| coil, courage 25, lcd display |
