Old 10-16-2025, 11:50 AM
Default Command Pro
Hello all, I have a 22hp command pro with a big hole in block.
MOD# CV22S. Funny thing is it still ran beautifully, except
it runs out of oil real fast.
Not sure where I am going with this but thought if I could find
a donor I would think about replacing it.
I am not exactly sure how you even find a direct replacement but
thought I would start here. Hope you all are well.
Ken
Old 10-18-2025, 07:19 AM
Look for a 2000 series Cub with a Kohler
Old 10-18-2025, 06:28 PM
Ozcub's Avatar
Ozcub Ozcub is offline
Hey Sam , Is the block "exactly" the same for a Vertical or Horizontal Kohler
Oz
Old 10-19-2025, 08:43 AM
Thanks Sam. Be a tough thing to find around here but it gives
me a starting place.
Ken
Old 10-19-2025, 09:04 AM
CV is a vertical engine. I'm pretty sure a CH block will not work. There should be a few of throw away mowers using a CV that would probably be cheaper than a Cub.
Old 10-19-2025, 11:12 AM
ironman's Avatar
ironman ironman is offline
This is what I found.....
Old 10-19-2025, 11:44 AM
Thumbs down
In other words, forget about it!
Old 10-19-2025, 06:06 PM
Ozcub's Avatar
No , just keep looking
Oz
Old 10-19-2025, 08:54 PM
As always lots of good things to ponder. Thanks. I am most assuredly
only interested in a straight plug in. The days of buying things
hoping I can figure it out are done. Unless it's an old Cub. Maybe a 782
Ken
Old 10-20-2025, 10:26 AM
RLause's Avatar
RLause RLause is offline
Depending on where the hole is and the size, maybe it could be patched. A patch shaped to cover the hole, secured with screws and JB Weld used to seal between the crankcase and the patch. Has been done before.
Richard
