Old 01-14-2026, 08:47 PM
StakorEights's Avatar
StakorEights StakorEights is offline
Default New from Southwestern ohio
Hi guys,
This seems like a place I could get information or how to tips or whatever. I uhh pull stuff out of the Junk pile. That's where I got my 71, and 127 parts tractor, and we pulled a 154 Cub lo boy out of there, and countless other lawn mowers. Now I recently, got a couple more, just not home yet. So yeah.
Anywho I have a 1967 Cub Cadet 71, with a plow, which I'm pretty sure is a cub plow. Fun fact you can mount up 5 lug ford wheels to a 5 lug cub so, the more you know.
I hope to learn something, and if anything atleast show others my jerry rigged cub cadet plow!
Old 01-15-2026, 12:11 PM
CubDieselFan's Avatar
Welcome to Only Cub Cadets.
Old 01-15-2026, 02:54 PM
welcome
unless the engine is seized I would expect the 127 will run after adding a S/G
Old 01-15-2026, 04:34 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
It may not have the original engine, but it has the 147 frame and remnants of the electric lift. Hope you get it running!
Queen Of The Quietlines!
Old 01-15-2026, 09:25 PM
Actually that's probably correct, the hood has been repainted and the only way I figured it to be a 127 was it had a K301 and a hydro transmission. Is there any other differences between a 127 and 147? Thanks in advance!
Old 01-16-2026, 08:23 AM
Grandpa53 Grandpa53 is offline
The frame on the 147 below the flywheel is opened up to make room for the larger flywheel of the 14 hp Kohler vs the straight frame of the smaller flywheel engine equipped 127.
Old 01-16-2026, 08:38 AM
ironman's Avatar
ironman ironman is offline
Like this....
Old 01-16-2026, 08:48 AM
IHCubCadet147's Avatar
Welcome to OCC! In addition to what they said about the frame, all 147s came standard with headlights, taillights, and an electric lift. They were options on the other models. It’s pretty common for the e-lift to fail and get replaced with a manual one as yours has been. They’re great tractors, and I’d say that one looks like it’s worth saving.
