Old 02-23-2026, 10:44 AM
SheThinksMyTractorSexy SheThinksMyTractorSexy is offline
Default Just acquired a Cub Cadet 102
Just bought a house and after side yard clean up we have found out we have an International Harvester Cub Cadet 102 that was hiding out in the bushes. According to neighbors it hasn’t moved in over 20 years and definitely has a rustic look going for it. I’d love to get it running and be the redneck riding it down the street. It has the tiller attachment on the back also. What things should I know about this tractor? I want to know everything about it! Thanks for any advice/knowledge.
Old 02-23-2026, 11:01 AM
The 102 is the 10HP model Cub that was part of the 3rd series of Cubs built from Aug 1965 thru Nov 1967. the 102 enjoyed a production run of some 30,615 units.
I see that you tiller has both the left and right side extensions on it as well! Nice!!
That effectively makes it a 42" unit like the model #2 that was offered a little later.
You have a little diamond in the rough there!
Here are some of the many attachments that were available for the 102.
102Attachment
220 32" Lawn Sweeper (190-220-100) 190-220-100
222 38" Lawn Sweeper (190-222-100) 190-222-100
368 10 Cu. Ft. HD Utility Cart (190-368-100/190-368A100/190-368B100) 190-368-100 190-368A100 190-368B100
38", 42" 3 Spindle Mower
38", 42", 48" 3 Spindle Deck Drive Unit & Hitch
42" Back Blade
42" Push Blade
425/425A 17 Cu. Ft. Utility Cart
438 Broadcast Spreader (190-438-100)
48" 3 Spindle Deck
521 Utility Cart (190-521-100)
653/653A 10 Cu. Ft. Utility Cart (190-653-100)
CC36, CC42 Snowthrower
CW36 Snowthrower
Gearbox #1
Helper Spring
Manual Lift Helper Spring & Handle Adapter
Peg Tooth Harrow
PTO Clutch, Engine Driven
QA36, QA42 Snowthrower
QA36A, QA42A Snowthrowers
Sand Trap Rake
Tiller #1
Tiller #1 Front Drive
Tiller #1A Front Drive
Tiller #2, Front Hanger
Trailer #1 Built 1960 - 1967
Old 02-28-2026, 11:08 PM
Any advice on mechanical aspects with engine/PTO ect. I doubt this thing will run if I tried. Just trying to think of options. Is there schematics for this machine as well? I’m not going to get rid of it but are these worth much?
Old 03-01-2026, 12:17 AM
Ozcub's Avatar
Ozcub Ozcub is offline
Top of the page you will see Parts and Service look-up start there with your search for info
Old 03-01-2026, 10:00 AM
Ambush Ambush is offline
Nice bonus on the house purchase!
First off, don’t try to start it or turn it over right away. Pull the spark plug and dribble in a table spoon of engine oil then a couple shots of penetrating oil. Let it sit at least a week, then turn it over by hand. If that seems smooth, take the carb off and thoroughly disassemble, clean and put in a rebuild kit. When it’s turn over time, first check for spark with the plug out. If you have spark, feed it some fresh gas from a small, clean tank or bottle. The tractor looks well cared for and unmolested just judging by the pictures. Well worth the time!
It might be a smoker that needs a rebuild, or have a major engine issue. Good also be they got a new mower and just parked that one. Good luck!
Old 03-01-2026, 11:21 AM
Farmall450's Avatar
With that Cali weather it probably isn't in too bad of shape even sitting out.
OP, to answer your previous question, they aren't worth more than a few hundo in running/decent condition, at least by me.
But all it needs from you is likely a battery, carb cleaning, points cleaning, and some front tires or tubes.
