Old 12-05-2010, 05:13 PM
1966cub102 1966cub102 is offline
Default 782 series 1 or series 2 which is better?
I just got 2 782s one is from Cleavland the other from Brownsville. The Cleavland is a series 2 Both are kinda rough but the cleavland looks to be the later made one and a little better shape.My question is would one be more desireable to restore than the other? any opinions are welcome thanks
Old 12-05-2010, 05:40 PM
The series II is the better engine with pressure lubrication. The series I is splash lube.
Since both tractors are CCC-built, neither is going to be more desiriable than the other to restore. However, if one of them has a serial number below 719,999, it should have a cast iron rearend, and that would be the one I'd want to keep if it were me. If you're planning on restoring one, use all of the best parts and then reassemble the not-so-good parts onto the other tractor.
Old 12-05-2010, 05:42 PM
The series 2 engine is a better choice with higher pressure oiling and full pressure to the rod bearings, instead of a splash system.
Old 12-05-2010, 05:43 PM
No fair Matt,
you type faster than this old goat, Ha.LOL!
Old 12-05-2010, 05:49 PM
Default cast iron rear
yes the brownsville one is 704200 cast iron rear. as far as restore ,I guess what I really mean is refurbish to working condition.Thanks
Old 12-05-2010, 06:08 PM
Actually, Matt G is NOT totally correct. Both the KT-17 Series I and Series II had a pressurized lubrication system. There difference was in the Rod Journal lubrication. Series I relied on the Splash method while Series II had pressurized journals. Thus, the Series II would be the better version. As per the Kohler Service Manual.....
Old 12-05-2010, 06:22 PM
Default ah ha that might explain some thing
The series 1 appears to be stuck I wont say seized because I know there are a couple things it could be and I havent got too far into it. I may not have 2 good motors the series2 will spin by hand which is a good start
Old 12-05-2010, 06:38 PM
I thought I said that?
Old 12-07-2010, 11:06 PM
Jimkin Jimkin is offline
Default 782 just starting
Getting the 782's ready for revamp. that cast iron rear on the one is the way to go. like I told you when your ready I have the fenders and hood for you just stop buy.
Jim with 82,s
Tags
782, red
