Old 06-01-2009, 10:25 AM
jcrashbox jcrashbox is offline
Default PTO and creeper box?
I have a 129, can I add a creeper box and a rear PTO shaft to it? How much work is involved?
Thanks
Crash
Old 06-01-2009, 11:32 AM
The Creeper Option is for Gear Drives. There is NO need for one on a Hydro.
There were NO options for a rear PTO for the 129. BUT, that is not to say, one could not be custom fabricated.
Old 06-01-2009, 11:55 AM
That would make sense, I didn't think that one through apparently. Much appreciated. How about adding the 3 pt. or the single point lift. How hard will parts be to come by. Can I add hydraulic lift to put on a loader or would it be easier to find a cub that already has this option?
Thanks for all the imput, I am a newbe.
Crash
Old 06-01-2009, 01:36 PM
As far as Hydro's goes, there are two types. Ported and Non-Ported. See image for reference....
You need a Ported Hydro to have Implement lift on a Cub Cadet. The 129 did NOT come with a Ported Hydro from the Factory.
As far as the Cub Cadet 3 Pt Lift system, one can be added or installed on your Cub. Click on this link to our Technical Library Section to see what is needed.... Hitches
You can add a Front End Loader to a Cub BUT is needs an Axillary Hydraulic Pump and the front axle of the tractor needs beefing up.
Old 06-01-2009, 03:55 PM
I appreciate the info. This will definitely help.
