Old 01-22-2011, 11:07 PM
Superglyde Superglyde is offline
Default warming up the hydro?
When its 12 degrees outside, does the hydro take about 10 minutes or more of warming up before it goes? Just wondering if thats normal.
Works great after I do that, but for the first ten minutes, it doesn't move forward or reverse.
Thanks for all the experienced advice!
Carl
Old 01-22-2011, 11:13 PM
Yep, takes awhile to get that fluid moving. Should allow the engine to warm up slowly for that long anyway at low to mid throttle. Keeps from prematurely wearing out the engine components.
Old 01-22-2011, 11:15 PM
william1041200's Avatar
Talking
at 12 degrees I would assume any fluid would get thick, and move less freely.
I am in cecil county. how about you?
I cant give you the answer you need because all my machines are gear drives. sorry.
Old 01-22-2011, 11:28 PM
Mine howl a little more when they are cold but they seem to move alright.
But i do let them warm a little before i really start pushing them.
Old 01-23-2011, 01:55 AM
I suspect that one of my 123's has a little water in the trans/rear end.
When it's really cold it takes as much as 20 minutes for it to move.
Old 01-23-2011, 03:00 AM
aagitch's Avatar
aagitch aagitch is offline
When its cold out the 782 will whine some. I let it run at mid throttle for about 10 minutes or so. It'll move fine right away but I like to let it sit and warm up first.
Old 01-23-2011, 07:45 AM
toyman's Avatar
toyman toyman is offline
With the cold spell we're having, my 1862 is a little slow out of the gate but is fully functional.
Original Member #54
Old 01-23-2011, 09:32 AM
ktmrider ktmrider is offline
I did my first single digit temp snow blow the other day. And other than cranking REALLY SLOW once it fired up the hydro moved right away.
1971 Cub Cadet 129 38" deck & QA42A
Old 01-23-2011, 01:24 PM
Merk Merk is offline
by ktmrider
The is suppose to move as soon as the motor and hydro pump is turning. You are on the brink of having problems if the tractor doesn't move right away.
Old 01-23-2011, 01:47 PM
BCDSFCRET BCDSFCRET is offline
Default Brian D
I don't know what model of tractor you have. I would guess your hydro pump is worn. Your tractor should move as soon as you start it. I live here in Minnesota. My 782 with a snowblower starts up and moves at -10.
If you haven't changed the Hydrolic oil and filter, do that.
