Old 04-01-2011, 09:43 PM
FundFarm FundFarm is offline
Smile IH Cub Cadet 782; IA U1111 Tiller belt
I recently acquired an IH (red) Cub Cadet 782 in excellent shape! Since then, I also located and acquired a model IA U1111 tiller.
I desperately need to find out the belt size to fit this configuration.
If anyone has suggested websites or other information, it is MUCH appreciated!!!
I am also looking for someone that might be able to help me find 'extensions' for the tiller. It currently is 30" wide, but I would like to expande it a little on either side. At most, I would want it to be 42" wide.
All the help and guidance that I have found from this site is extraordinary.
Thank you in advance for your expert guidance!
If questions, Email: fund.joe@gmail.com; or call me; 785.213.5589.
Old 04-01-2011, 09:55 PM
Please make a post in the wanted section of the site for the extenstions.
The correct belt # is listed in the tech section of the site. Here's the link!
http://www.onlycubcadets.net/forum/showthread.php?t=25
Old 04-01-2011, 09:58 PM
The first thing you will have to do is make sure you have the correct bottom pulley on the angle gear drive for the tiller. Your 782 uses a 5/8" belt. The 1 and 1a tillers originally came with a pulley for a 1/2" belt for the early model tractors. There is a belt chart in the implement technical section on page 2 towards the bottom of the page under Tiller Belts. They give the belt number to order since I do believe it is NLA from cub.
Our sponsors at the top of the page should have all the parts you are wanting or can probably locate them. Patton Acres in particular should have. Also I would call or email them as they do not list 'everything' they have on their webpages.
Old 04-01-2011, 10:02 PM
You will need to use the belt listings for the 2b tiller. Also you will need to know your serial number and use the belt per your serial number.
Old 04-01-2011, 10:08 PM
Just to make sure. Do you do have the cast iron rear end in your 782?
Old 04-02-2011, 09:26 PM
wig wig is offline
Why does it matter if it has the cast rearend or not?
Red 782 w/dual hydraulics & Ags. Power angle snow blade, QA 36A snow thrower, rear IH blade, tiller, #2 trailer, mower, custom made winter cab and brinly plow.
Old 04-02-2011, 09:36 PM
There is a difference of about 8 inches in belts depending on your serial number. What is your serial number?
Old 04-03-2011, 03:15 PM
Default IH Cub Cadet 782; IA U1111 Tiller Belt
The Serial Number on the IH Cub 782 is: 2050601 U740301
This is the complete string of digits on the Serial Number plate; it also has Model 145782399.
I have looked at a number of web-sites and forums; most identify needing a belt that is 21/32 x 154 5/16.
I plan to take a look at the pulleys this afternoon.
Thanks again for your guidance!
Old 04-03-2011, 03:29 PM
Since you have an aluminum rearend, this isn't going to be as easy. The tiller gearbox will not bolt to the aluminum rearend, so you have a few options:
1. Change the rearend to a cast iron one from an earlier model hydro Cub Cadet. This is probably the easiest option.
2. Get a bagger plate and bolt the tiller gearbox to that. A different length belt will be required. This is probably the cheapest option.
3. Get a Cat-0 3-point and build a copy of the adapter package that was sold to adapt the earlier tillers to the tractors with aluminum rearends. I did this with my 782D. I still need to find a belt so I can use it. This is complicated and expensive but is the most 'factory correct'.
Old 04-03-2011, 04:05 PM
I have yet to have one with the Al. rear, didn't think about it not hooking up. What is the difference then in the two different belt lengths mentioned in the belt graph?
