Old 05-29-2012, 04:54 PM
Cannon51's Avatar
Cannon51 Cannon51 is offline
Default My first Cub, an 1863
Yesterday a friend of mine gave me an 1863 he bought new in 1995. It has not been used in a couple of years but it did crank and drive on and off the trailer. I cannot find a part number for the broken transmission lever, unless it is part of the cross shaft assembly. Also all my other hydrostatic tractors have a way to disengage the transmission, I cannot find one on this. The way you see it on the trailer is the way I picked it up except for the vise grips clamped on the transmission rod in the drive shaft tunnel he was using to drive it.
Old 05-29-2012, 04:59 PM
Congrats on your 1863! I have a 1864 and love it! They have auto release valves.
Parts look up for the hydro handle.
http://www.cubcadet.com/webapp/wcs/s...A/040030700004
Old 05-29-2012, 05:46 PM
Welcome to OCC!!
Looks like your 1863 needs a similar "update" to the update I did on my 1861!!
My daughter mows her place weekly with this one!! A short drive through the woods!!
Old 05-29-2012, 06:19 PM
Sounds like just minor issues. A little work and it can be looking and run like new.
Old 05-29-2012, 06:21 PM
Cannon51's Avatar
Methos, the part that is broken is the rod that bolts onto the cross shaft #3 and that #4 and #5 screw onto. Though that rod bolts on it may not be a separate part. The third picture shows the broken rod that I have since removed. Thanks for the reply.
Cadplans. that does look a lot cooler than the plastic hood and side panels.
Cannon
Old 05-29-2012, 06:42 PM
Cannon
Very common issue. It was only riveted from the factory. The red in the pic. If you have the handle it can be bolted, welded or simply replaced. You will need to remove the dash to get at it. Kind of a PITA but not all that hard.
Old 05-29-2012, 07:07 PM
Cannon51's Avatar
Yes the 2 red marks were small hex head bolts on mine. I was able to remove them after taking the battery out. I don't have the rod but if my friend can find it I could weld it back together. Thanks
Cannon
Old 05-29-2012, 07:54 PM
brentwd's Avatar
brentwd brentwd is offline
I have a 1641 that I am parting out. If there is anything you would need PM me and we'll talk.
Old 05-29-2012, 07:57 PM
The 1863 uses a Hydro-Gear brand pump and it should have a release lever on the rear left corner of the tunnel cover. Here is a pic of mine and if you look close you can see the round knob.
Old 05-29-2012, 08:01 PM
I got the same knob.
