Can anyone tell me what the stock tire size is for my 1450? As you can see I bought it without rubber so I have nothing to go on.
Sources for tires would also be helpful. I also need to know what kind of hydraulic fluid to use on it as the system is dry at this time. The motor is dry but I assume that 10-30w would be sufficient for that. Thank you in advance Bill |
Given it has the stock rims, it takes 23 10.50-12 on the rear and 16 6.50-8 front. The hydrostatic system takes non synthetic hy trans that you can get at your local cub dealer.
This is the recommended Hydro Fluid............. Hydro Fluid
This is the recommended Kohler lubricants.......... Engine Oil
Do not use 10W30! Use SAE30 instead.
1200, 1450, Red 782 |
Thank you for the information.
I will get the SAE 30 and HYTRAN from a cub dealer Hopefully tractor supply will have the tires at a reasonable price. |
126 in surgery with weights, spring assist, 3 point and sleeve hitch 100 with woods finish mower and rear lift, Nice 125 with super nice sweepster, 1782 Super Diesel, 1650,782D in surgery, 102 parts tractor.. 3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
Oh well, you can rest assured that I will not be putting much weight on any of their opinions. |
Your dealer should have the correct tranny fluid. Most of the dealers don't know the old Cub Cadets. Mine sure doesn't.
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
Has anyone used Traveller® Universal Tractor Trans/Hydraulic Fluid that is sold at tractor supply?
It indicates on the package that it is recommended for: Case HY-TRAN Ultra (MS-1209) Case HY-TRAN Plus (MS-1207) Case TCH Fluid MS-1210 (JIC 145) International Harvester HY-TRAN B-6 International Harvester HY-TRANS Plus (MS-1207) To name just a few. The cub manual states HY-Tran B-6 which is listed
