Old 05-14-2013, 09:58 PM
Chris08527 Chris08527 is offline
Default LTX 1040 belt/blade issue
I had my tractor serviced at a local shop for a tune up like I do every year. They put a new belt on the deck that drives the blades and now I have 2 problems . . .1. the belt keeps popping off and I can not figure out why, it was good for 2 total lawn cuts about 1 hour per cut. myself and a buddy took the deck off to take a look and out the belt back on, still pops off. why does the belt keep popping, what i am missing/doing wrong?
2. Now the blades are out of sync and will hit each other when spinning . . .is there some sort of timing adjustment for the blades???
any help would be great . . .thanks
Chris
Old 05-15-2013, 12:34 AM
cubby102's Avatar
cubby102 cubby102 is offline
Sounds like I'd take it back and ask em what they did wrong. I wouldn't think that is a timed deck (I could be wrong) so maybe they put tonlarge of blades and wrong belt on
1872 - 60"haban 54" power angle haban blade
'63 Original - restoration project
582 -tiller
147 - leaf duty with bagger.
1811 - Ditch mower
800 - have it just cuz its a 800
Old 05-15-2013, 12:38 AM
cubby102's Avatar
With a little research I seen there was a sercice bullitan on the timed deck. Apparently a lot of peoe are having trouble keeping them in time
582 -tiller
1811 - Ditch mower
Old 05-15-2013, 07:09 AM
I don't think they put the wrong blades on, because I cut the lawn with it twice after they serviced it...after the belt popped off for the second time I started having issues with the blades???
Old 05-25-2013, 08:47 AM
dontheo dontheo is offline
Do you have both of the spindle covers installed? I have a 2009 and never had a problem till one of the covers cracked a eventually just feel off. Then just a small twig would pop that sucker. I finally replaced the cover and went through last season without problems.
Just a thought.
Old 07-15-2013, 07:58 PM
Khackee Khackee is offline
Default I have same problem
There is a tsb on that deck, there is a small retainer that is retrofit on the deck, ask your dealer. Also look for cracked flat washers on the deck, feel free to email me
Old 07-16-2013, 06:38 PM
garnold's Avatar
garnold garnold is offline
SAME THING!!!
Holy cow I was just going to ask for some help with my 1042 here and wouldn't you know it one of the first posts is about the same issue. The belt continues to fall off this thing I get a few cuts then BAMMM the belt comes off again. So people are saying there is a recall or something? I'll have to contact my dealer to see what's up but wanted to ask around. I did find this YouTube link of a guy that seems to have fixed his. What do you think?
http://www.youtube.com/watch?v=T7w-fDSoU_o
Old 07-27-2013, 07:17 AM
Default I hope I can help you
Hi there. I cussed my 2009 LTX 1040 many many times because of the timed deck issue. I finally narrowed the problem down to 2 things. Biggest problem was that one of the shoulder spacers was cracked in half. Its part #10 on the scematic.
http://www.cubcadet.com/webapp/wcs/s...A/769045870028
Part10 738-04162A Shoulder Spacer, .884 x .190 (These break frequently)
And there is a small retrofit kit that helps its 759-04229-$6.37
I also had to replace part 20 783-05802-0637 Bracket, Idler
and also part 13 783-06176-0637 Idler Brace Bracket
Those 2 Brackets were bent, from what I dont know.
If you need a PDF of the parts scematic let me know. Good Luck
BTW if you put in code "chatwithus" at checkout you get %10 off.
Got my parts in 3 days.
