Old 07-06-2017, 09:11 AM
coinman66 coinman66 is offline
Default Cub Cadet 1720 hydro fill question
Ok so I took a hand suction pump and emptied the 1720 hydro resevoir the best I could. So do I take the rubber insert out of the fill cup and fill it to the top or leave the rubber insert in and fill it up?
I assume I can use 20w 50 oil in hydro?
Old 07-06-2017, 10:45 AM
There are three generations of the 1720, depending on the serial number range. The transmission fluid will depend on what transmission used. What is your chassis serial number..??
Old 07-06-2017, 11:41 AM
Here is ID tag.
Old 07-06-2017, 12:39 PM
Your model is of the First Generation (1989).
The recommended Hydro Fluid is this..... Hydro Fluid
Old 07-06-2017, 01:33 PM
Whoops, I already put 20w 50 in it.....
Should I suck it out and refill?
Old 07-06-2017, 01:52 PM
I posted what was recommended.
You can use what ever you like.
