Old 04-10-2019, 07:03 AM
gregcobb gregcobb is offline
Default LT 1040 PTO not engaging properly
My LT1040 doesn't engage the blades properly. the spindles and belt are new. The lever which engages the blade is a bit bent and doesn't pull the cable forward properly. I am going to replace the cable as well. but not sure how to get the lever out .
Wonder if anyone has seen this before?? If anyone has a trick to get the lever out, please advise. I'm hoping it's not as difficult as it looks.
Old 04-10-2019, 07:38 AM
Leadslingingdaddy's Avatar
Isn't it that the lever/engages an idler to keep the belt tight? ? Are you talking Part #42?
https://www.partstree.com/parts/cub-...-1c097h-after/
Old 04-11-2019, 06:57 AM
I had a similar situation with my Z-turn and found out it was just a bad safety switch. Replaced all 3 of those boogers and no more problem.
Old 05-19-2019, 10:27 AM
samporter samporter is offline
i broke my cable , having the same prob.there is no info on replacing the blade engage cable ANY where , that i can find. It looks like you have to take the mower totally apart.
Old 05-19-2019, 12:27 PM
cooperino's Avatar
Sam. Please start you own thread. Take some pictures and show us whats going on
