I have a 1961 Cub Cadet Original and I recently bought a 3 Point/ Sleeve hitch for it that bolts into the rear of the rear end. How long should the extended bolts have to be into the rear end and how much should I torque them down to?
The bolts should 1/4" longer than what comes out, or 3/8"-16 x 1.25" Grade 5. Torque Charts are indicating 30 FtLb.
I've heard if I tighten them too far or if I get bolts a little to long, I could break the rear end. Is that true? I'm getting bolts from my local hardware store
Yes it is VERY TRUE!!
You do not want to do that as they will leak forevermore!! What's on there now, just the drawbar?? If so, just add the thickness of whatever you are going to add, be it a single lower section or the dual sections some use and you will have the length of bolt you need. |
Edit: I was pretty sure I put 1 1/4" bolts in the 149 when bolting on a 1/4" plate, but obviously I am wrong. I did run a bottoming tap in first to get max thread depth.
Parts book calls for 3/8" x 16 X 5/8" w/no drawbar
Where does one find a 5/8" long bolt?
Got a hacksaw??
Fastenal has a lot of different sizes.
Here is 3/8's x16 tpi x 5/8's Link: https://www.fastenal.com/products/details/12102 . |
