Old 06-05-2009, 10:14 AM
MFP8055 MFP8055 is offline
Default Ross steering box parts
I've read several great threads on rebuilding the Ross steering box used on wide frame models (1650). Is there a good source for the ball bearings, felt seal, and cam follower pin? I can probably machine the pin, but the balls are corroded and should be replaced. The felt seal on the cover plate is torn also.
IH 1650, CC 1210, 1610 and Bolens 1257
Old 06-05-2009, 10:31 AM
dross dross is offline
I heard the other day Jd 110 used the same box and cheaper. I pulled apart an Allis Chalmers 416 years ago that had a lot beefier type cage but I havn't had a chance to see if thier still available.
Old 06-05-2009, 10:43 AM
klejeune's Avatar
klejeune klejeune is offline
I've read that the internal parts are the same for the JD 110 or similar models. Not sure the exact model.
Part number I saved:
Taper Stud - M42260
Plug, Adjusting - M43745
Seal, Foam - M41917
Cap, Steering Wheel Assy - M43800
Bearing Kit - AM30867
I need to get these to rebuild the column in my 1450, but haven't been down to the Deere dealer to check costs yet. Im afraid my shoes will melt if I pass through the door there. j/k...
I like pie
Old 06-05-2009, 11:36 AM
clint clint is offline
I have this same project in front of me, if the problem is play in the steering shaft. I have not dug into it yet as I'm stuck working on so many other things ( just on the 1450 !!) and my main hang up at the moment is rebuilding the drive shaft etc. Does anyone have a link or pictures of what exactly goes wrong with the shaft causing all the play?
Are the bearings special, if not one could easily cross reference the number, other than that looks to be special items.
Old 06-05-2009, 02:27 PM
drysumpjet's Avatar
drysumpjet drysumpjet is offline
Default Source for steering box parts/repairs
http://search.ebay.com/_W0QQsassZgll11djQQhtZ-1
I have had great luck with Mr. Louderback's work and his auction site store.
He built me a custom steering box that added an additional turn lock-to-lock which eases turning effort substantially when using front implements or weights.
Old 06-05-2009, 04:29 PM
The guys are correct about the JD parts being the same, and they are quite a lot cheaper than buying from the Cub store.
klejeune, if you keep your Cub Cadet key in your pocket while you are in the JD store, and rub it like a lucky rabbits foot, your shoes WILL NOT melt.
drysumpjet, is also correct, Mr. Louderback does very good work.
Old 06-06-2009, 06:26 AM
You could contact the Forum Sponsors that would gladly help you.
Old 06-06-2009, 09:24 PM
aagitch's Avatar
aagitch aagitch is offline
All that play in the driveshaft is usually caused by the self-aligning bushing that gets worn out. The ends of your driveshaft may be worn down from all the play.
