-   -   battery cables? (https://www.onlycubcadets.net/forum/showthread.php?t=29595)
gmbadgley 01-24-2014 08:24 PM
Originally Posted by Sam Mac (Post 239183)
Don't remember what the solder is, something I've had for years.
Here is a link for welding cable.
http://www.wireandcabletogo.com/Weld...FcEDOgodNWkAUw
For Electrical use, always use Flux core solder. Acid core solder (for plumbing)will corrode.
For cable, you can NEVER go too big!!
Greg
nikster 01-24-2014 08:50 PM
I had to run new cable when I was redoing the charging system when i had my boat. I found a welding supply house cheaper to buy any gauge wire as opposed to Lowes or Home Depot.
NIK.
Cubby guy 01-25-2014 10:45 AM
Greg had it right..acid core/flux solder is for plumbing only.
Resin core/flux solder for everything else.
I found that out early on in my work life, I mistakenly used acid core on an electronic repair...that stuff etched the copper runs right off the PC board. :Duh::Duh:
DoubleO7 01-25-2014 10:52 AM
It is also better to use tinned copper wire which is also the go-to stuff for use on boats.
And use wire that consists of many fine copper strands versus a few large strands.
bill682 01-25-2014 12:41 PM
I had a cable made a couple years ago from this site. They use top quality marine grade components. It only cost about 10.00 shipped to my door. I think I used 4 gauge with heavy duty ends and shrink tubing.
http://www.genuinedealz.com/custom-cables
