Old 01-24-2014, 12:46 PM
mmzullo mmzullo is offline
Default battery cables?
Who makes there own battery cables? If so what wire do you use? #10 or is it #8. 10 looks thin. I was even thinking going to #6.
Old 01-24-2014, 01:27 PM
I use #2 gage and I solder the ends on.
Old 01-24-2014, 01:39 PM
Calvins66Cub's Avatar
and heat shrink tubing.
1966__122 Cub Cadet.
Owner: Calvin, 6 yrs old
Dad: Craig
Old 01-24-2014, 01:46 PM
#2 wow that's heavy.I guess heavier is better. What solder do you use?
Old 01-24-2014, 01:55 PM
Don't remember what the solder is, something I've had for years.
Here is a link for welding cable.
http://www.wireandcabletogo.com/Weld...FcEDOgodNWkAUw
Old 01-24-2014, 02:04 PM
General purpose flux core solder.
60%tin/40%lead
.06 diameter
Dad: Craig
Old 01-24-2014, 02:31 PM
Thanks. I'll see if i can find cable and ends
Old 01-24-2014, 03:37 PM
Here is a link for cable ends.
http://www.wiringproducts.com/copper...FYw7OgoduxAAFg
You can find them at Lowes or TSC you should also be able to get cable at TSC
I put the end in the vise open end facing up, heat it with a propane torch, melt the solder in it till it full then slip the cable into the molten solder. I continue heating it till the solder has soaked into the cable. Cool it off, clean it up slip the heat shrink tube over it and heat that with a heat gun.
Old 01-24-2014, 04:31 PM
Do you guys still use #2 gauge to the starter also. I want to run new cables on my 149.
Old 01-24-2014, 04:41 PM
Here is a link to wire size amperage capacity. It is a marine rated chart, but good for reference.
http://www.westmarine.com/webapp/wcs...e#.UuLdHhDn9hE
#2 is a little overkill for the starter wire, but I like heavy-duty.
#6 would be a minimum for starter wire, IMO.
Dad: Craig
