Old 01-02-2013, 09:02 PM
72-149's Avatar
72-149 72-149 is offline
Default are the lift rods different on the 451 snow blower
i was woundering if the lift rods for the GT's are different lenghs to the supers ?
Old 01-03-2013, 06:29 AM
Did you look in the Installation Manual....??..... 451 Installation Manual
Old 01-04-2013, 03:08 AM
72-149's Avatar
OK, I guess what I'm trying to say is, are the arms adjusted different length for the super to the GT's
Old 01-04-2013, 06:12 AM
You are not giving anyone much information to answer your question.
What is it that you are specifically trying to do...???
Old 01-04-2013, 08:06 AM
cubs-n-bxrs's Avatar
I would think there is a differance between supers and regular gt's because of the dropdown brackets. When I acquired my 451 there was no lift rod with it so I just fabbed up my own with about 4" of adjustment on either end of the rod.
Old 01-04-2013, 04:00 PM
72-149's Avatar
im trying to get the tractor (red 982) to lift the (white 451) snow blower i put the rod on and it starts to lift but gets at the end of the lift cycle for the clinder it looks to be like it needs to be longer the lift rod,i can unscrew it to make it longer ,was just woundering it this is right i dont want to bend or tdo some thing thats not right !!!
Old 01-04-2013, 04:05 PM
OK....you are attempting to install a 451 snowblower on to a 982.
I'll do some digging.
Old 01-04-2013, 04:10 PM
According to the Attachment Guide, the 451 wasn't designed for the 982.
Old 01-04-2013, 05:02 PM
The physical size and shape are the same between the 2 throwers. The only difference is the gearbox on the unit.
Old 01-04-2013, 05:25 PM
One can always modify and adapt.
