Old 05-19-2015, 01:37 PM
snoel's Avatar
snoel snoel is offline
Default The KY 782 ??? is MTD
Not at all what I expected, on several levels. MTD, not IH. Not in the condition I was expecting. 682 on hood, (no biggy). More rust than showing in pictures.
And 4700 hours on meter! But, runs nice . I should have driven the 60 miles each way to look for my self. So grin and work harder!
Has the 44C deck (with noisy bearings).
Has the Cub "3PT", but no sleeve or pulling hitch.
Frame to axle bolts tight.
Now, some info please.
Model: 143782399
Serial #2050601U721118
Where can I find data info for MTD built CCs.
Is it actually a 782, and what year? It does have the hydraulic lift.
Any other information, I need to be especially mindful of?
And I promise not to be a pest, with loads of unnecessary questions, if you all will just get me past these first few.
Thanks,
Steve
Old 05-19-2015, 01:44 PM
CubDieselFan's Avatar
I do not much about these. Does it have a cast rear? Some of the early MTD's had cast, but I am not sure how many. If it is aluminum then it is a MTD. With that many hours, I would think it would be on at least its second engine and maybe a third.
Old 05-19-2015, 02:31 PM
snoel's Avatar
Aluminum rear.
Steve
Old 05-19-2015, 04:18 PM
SGragg SGragg is offline
Inactive Member
Believe the Owner's Manual in the Technical section would apply...
http://www.onlycubcadets.net/forum/s...ead.php?t=4666
Stanton
1980 IH 782, Kohler M18
IH #1 Cart, original
2015 XT2, Kawasaki 23 HP
Old 05-19-2015, 04:41 PM
snoel's Avatar
That link appears to be for the IH models.
Steve
Old 05-19-2015, 05:07 PM
Yep, that is a 1983 782. Be careful if it has the Cub 3 point on the aluminum rear unless it has the bracket like Xtreme makes. This machine should have the "maintenance minder" type hour meter so I'm thinking the hours are not correct. Lets see some pics.
Old 05-20-2015, 12:39 PM
snoel's Avatar
The more I look, the more I think the hour meter is right. Desperate for maintenance (which I've already started). No pics for a while. It's ashamed to have it's portrait taken, just yet.
Steve
Old 05-22-2015, 10:27 PM
snoel's Avatar
Pulled engine tins and cleaned everything out. Note: some stuff called, Awesome, is a great de-greaser, and it's cheap! Pulled plugs to remove tins, and left side is running rich, or maybe the right is lean. Going to check for vac leaks. Adjusted travel control linkage. Removed old seat pan, for replacement. Guess I'll go to Tractor supply tomorrow. Never had a new garden tractor seat. Decisions. Hate to spend a lot on a seat. Someone will just buy the tractor, (like they did the Case today ), and I will just have to start over. sigh....!!
Steve
Old 05-23-2015, 01:43 AM
The pictures before, during and after is the good stuff.... Then everyone can see the transformation of another's junk into a diamond.
Old 05-23-2015, 07:52 AM
snoel's Avatar
The CL pic.
Steve
