Old 06-06-2015, 10:30 AM
cub125 cub125 is offline
Default K-241 resister?
I broke the ceramic resister going to my coil when I was putting the shroud back on, if I understand it correctly it reduces 12v down to 6v for the ignition coil. Can I just replace my coil with a 12v coil and do away with the resister?
Old 06-06-2015, 11:08 AM
DeltaCub's Avatar
DeltaCub DeltaCub is online now
The ceramic resistor does decrease the voltage. Voltages after the resistor are typically 6-9 volts. I would recommend installing the coil that is designed for the Kohler "K"series engines as it has the proper resistance built in.
Queen Of The Quietlines!
Old 06-06-2015, 11:17 AM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
the resistor most people use was used on the 60's - 70's Chrysler products. if you put a stock Kohler coil on you don't need it
Old 06-06-2015, 06:20 PM
Ditto...........
Old 06-07-2015, 12:30 AM
I picked up the new coil today, no need for a external resistor now, Thanks!
