Guys, I searched hi and lo in my manuals and only found one instance where it said the Hydro Unit take 8 its of HyTran which seems way to much. I thought it was around 4 or 5 qts.
Can anyone verify the fluid amount with a new filter please? ![]()
_________________ Godspeed, 107, 109 (2), 125, 129, 147 (pieces), 149, 1650, 1650 w/ Johnson FEL, and 1572 Diesel, 1958 Farmall Cub |
Sorry, this is in my 1572 w/ Aluminum rear case
It is going to be around 7 quarts. There is a lot of reading on here on what type to get so I will not go into that.
1572, 1864 x2, 1810 x2, 1863 & GT1554(Dad's Ole Mowers), 1811,782D, 1872 x2, 782DT(Sold), 3235, 1860, 1772 with 3-point and Turbo. |
Yep 7-8 QTS.
You make NO mention of the model of tractor you are working. Assuming you are working on a pre 1990 product, did you search here....??? http://www.onlycubcadets.net/forum/showthread.php?p=30471#post30471
Thx everyone for the confirmation.
Roland, Sorry I Forgot model 1572 in the Title, so I mentioned that it was a 1572 in the 2nd post on this thread. Thx for the link to confirm 7 to 8 qts.
Does anyone run a 'lighter' fluid in the winter months?
![]() Quote:
Just a FYI:
If you decide to go with an alternative, there is a "303" tractor hyd fluid that is a bit heavier and causes problems in winter in some equipment. Some report it takes forever to warm up. I tried it once and quickly changed to hyguard as I had some on hand. ![]() |
Thx Roland, I didn’t know that
Thread Tools | |
Display Modes | |
