I have been contemplating building the mounts to angle the blade on my 1650with dual hydro. I have built the mounts and planned on using a lift cylinder from a quietline. After looking at some photo's of other kits I realized the piston on the cylinder might be to small. I know the cylinder will have to be redone as the ports will exit to the rear and not at top or bottom. Any ideas would be welcome.
Try using a cylinder from a 149 or a 169. They match the original style.
I used a 1.50" bore x 7" stroke cylinder for mine.
![]() Here's the factory setup.
Adam 1964 Model 100 w/ K301 12hp and custom hydraulics 1972 Model 149 turned 129 w/ K301 12hp, triple hydraulics, 66 series clone |
![]() Quote:
Adam sweet as always!
I built my own using original brackets for the larger cylinder and used a hydraulic cylinder off of a combine head lift. Cant remember what brand of combine, but I went to a combine salvage yard and had lots to pick from, Had original cylinder to base my measurements from and the one closest I had to just shorten the ram by cutting a little off and rebrilling for the pin on the end. The one I ended up using also had a 1" ram. It will never bend. Good luck and if I can answer any more questions just email me.
Red 782 w/dual hydraulics & Ags. Power angle snow blade, QA 36A snow thrower, rear IH blade, tiller, #2 trailer, mower, custom made winter cab and brinly plow. |
