Need advice on removing a busted roll pin from rock shaft at the lift arm. Any advice? I am new to cubs and this is my first problem, does this happen often?I had the plow locked down - oops! I have an IH dealer close by, I hope they have them, if not where do I get one?
Sure do love my 149! |
partstree .com you get the size that you need
Or go to the IH dealer and tell him you want a COILED pin, not a ROLL pin.
JD dealers have them also if you have one near. they are much stronger/forgiving than a roll pin |
In order to remove the broken pin you need to be able to put a punch on it and then be able to hit it with a hammer. If it does not move hit it harder and then if it still does not move get a bigger hammer. Once it starts to move it should tap out fairly easy. Tap the new one in with a hammer.
With my son, EricR Super 2084 with 54" mower, 451 blower. 2086 with 3 pt hitch, 54 inch deck, 551 blower, 54 in brinly blade. A 4 digit original w deck. A 70 with deck. 2 102s both with 42 in decks, one with creeper, 1 36 inch IH snow thrower CW36, 1 42 inch IH blade. 149 with mower. 2072 w 3 pt hitch, Johnny bucket, 60 in mower, 451 blower. Jacobson GT 10 with mower. DR Lawn vac tow behind,Home made lawn roller. Brinly cart, 2 off brand carts and 1 home made cart. |
Buy a Coiled Pin PUNCH! Stepped drive end.
I agree. Best investment I made for those pins.
Josh Diesel Cub Cadets........... |
Where can you get a set of those? thanks adrian
is this the same thing i would need to use on the drive shaft that goes for the motor to the hidro pump
Tha's what they are called,punches at Sears !
DaDuke of 2145,1864,1811,1810,1541,1330,1210,1020,1641,147,1 24,73, IH FARMALL CUB. 7254, 1863, IH 982 ![]()
Thanks for the help fella's! IH dealer had the pins $2.50 each - I bought 2. What a bear to get the old one out. This forum is the best!
