Old 09-30-2013, 02:02 PM
samiam44 samiam44 is offline
Default Cylinder head temp?
Guys,
My K341 I was working pretty hard in really deep grass on a hot day. It stalled and wouldn't re-start till it cooled off. The only thing I can think of is cylinder wall to piston clearance with the aftermarket piston is too tight or ..it's overheating. It doesn't seem to be running lean- maybe I should enrich-en the fuel mixture a 1/4 turn just to be safe. Don't want to be too rich either..
I was wondering what type of head temp I should see on a 100F day w/ heavy load?? I've got an IR thermometer.
Michael
Old 09-30-2013, 03:33 PM
mmzullo mmzullo is offline
It could be the dreaded exhaust valve sticking or stuck. Do you run MMO in the oil.
Old 09-30-2013, 05:44 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
that would be my guess. if the piston was scuffing the wall you would have some other issues
Old 09-30-2013, 09:25 PM
Yes I run MMO. Only way to know is tear it back apart. Runs good.
Old 09-30-2013, 09:56 PM
New factory valves. New,guides reamed to fit.
Old 09-30-2013, 10:11 PM
Juicybusa Juicybusa is offline
Did you check spark? Intermittent coil failure is notoriously temperature dependent.
