Old 03-01-2014, 04:51 PM
Bob95065 Bob95065 is offline
Default Anyone Make a Pressure Washer Attachment?
I am looking for a used pressure washer and thought that one could be made for a CC. If I made a mule drive bracket like the ones used on a snow thrower or shredder that drove a pressure washer it could be very useful. The trouble is the pumps are very expensive especially the larger ones. Most of the broken pressure washers I see need pumps not engine work.
If I did this I would want a very long hose to keep spray away from the tractor. Other than that it should be something that could be done. If anyone has done this can you post pictures or a link to a thread that describes it?
Anyway, it was an idea I thought I would throw out there.
Old 03-01-2014, 07:08 PM
Sounds interesting, maybe a Cat pump mounted to the front of the mule on a slotted plate or something and depending on rotation and small belt it seems feasible. Mount a water tank on the rear and there you go.
Old 03-01-2014, 07:09 PM
Would be a cool setup!
Old 03-01-2014, 07:23 PM
c69ss396 c69ss396 is offline
If you had just the mount of a QA blower you could mount the pump in place of the *90 gearbox
Old 03-01-2014, 07:24 PM
I know this is not an attachment but it is a now a Cub pressure washer. Engine came out of a 1641. It was seriously messed up. I fixed the engine, sold the hard to start Tecumseh and replaced it with this 16HP Vanguard with electric start.
Old 03-01-2014, 07:29 PM
Wow that's awesome. Vanguards are hard to beat. Sam did you have to make some sort of adapter or did it just mount right up? I repowered my Coleman 70s pressure washer with a horr shaft Briggs in place of the Wisconsin that was on it and used some different double puller couplers from a bearing place but that looks like it just bolted up? My buddy runs a carpet cleaning machine with a vanguard that runs a cat pump with a love joy coupler. Interesting
Old 03-01-2014, 07:30 PM
Very cool Sam!
Old 03-02-2014, 01:36 PM
Try your local pawn shops, they often times have good stuff for a decent price.
Old 03-02-2014, 02:08 PM
This is exactly what I was describing and didn't even realize it existed. I stumbled on this at extreme motor works site which this is for a pincor generator but same idea. I guess they beat me to it!!
Old 03-02-2014, 02:54 PM
Yep that would work perfect.
