Old 11-04-2011, 09:53 PM
brentwd's Avatar
brentwd brentwd is offline
Default 129 into a 128
I have been wanting to find a 128. I have a chance to buy a 129 and possibly turn it into a 128. I know it will need a clutch and a new tunnel cover, but my concern is will the clutch pedal work the same as the brake and possibly anything else?
Old 11-04-2011, 10:13 PM
You wil also need a gear drive tranny...You need to study the parts lookup on the cub cadet web page,That will help you out a lot.
Old 11-04-2011, 10:15 PM
It'd be easier just to wait for a 128 to come along. By the time you buy all of the parts that are different, you could just about buy another tractor.
Old 11-05-2011, 07:04 AM
brentwd's Avatar
Thanks guys, I was talking about everything but the obvious. I already have the rearend, all I need is the clutch, drive shaft, and tunnel cover. Now back to the question I originally asked, will the clutch pedal still work?
Old 11-05-2011, 08:24 AM
I believe the pedal is the same, you just might need the piece where it hooks up under the frame. You could check a parts lookup or I could look at my 149 and 108 this weekend.
Randy
2 original cub cadets
1 100's
2 149's
1 73
1 2182
Old 11-05-2011, 08:43 AM
cub1200puller's Avatar
cub1200puller cub1200puller is offline
If you are going to mow with this tractor. I would stick with the hydro. To much shifting gears in a gear drive and thats not fun. you will also need the piece that goes on the clutch/brake pedal to acttuate the clutch. They are not the same on the hydros and gear drives and are a pain to put on.
2 Cub Cadet 1650's,1 with rear lift.
1 Cub Cadet 104, with lights, rear lift, spring assist and creeper.
1 Cub Cadet 129 with spring assist.
International 782.
QA-42A snow thrower
5 sets IH wheel weights.
Brinly 10" plow.
Brinly single disk.
3 front snow blades and severeal decks.
122,108,582 and 1200 pulling tractors
Old 11-05-2011, 09:17 PM
Cub128 Cub128 is offline
sent a P/M
1966 L106 Lawn ranger
1967 877 wheel-o-matic
1970 Raider 12
19?? 312-8
1972 Cub 128
1995 Cub 2145
1994 Craftsman GT 6000
2006 Vulcan Classic 1500
Old 11-05-2011, 10:08 PM
If you want a snowthrower tractor, you want a hydro. I'm a gear drive guy, but throwing snow with a gear drive isn't much fun. I did it once...never again.
