Is there some trick to prime the hydro pump on these things?
What happened to it that it needs priming? Did you service it?
1572, 1864 x2, 1810 x2, 1863 & GT1554(Dad's Ole Mowers), 1811,782D, 1872 x2, 782DT(Sold), 3235, 1860, 1772 with 3-point and Turbo. |
had to replace rear end do to broken case. now can't get it to prime
I have had to replace seals in a couple aluminum differentials and replace a broken case on a cast iron differential and have not had to prime the pump. An incorrect filter or a broken gerotor in the pump can cause the pump not to build pressure. Are you using a cub cadet transmission filter?
