Old 04-03-2011, 03:28 PM
william1041200's Avatar
Default hydro release valves
I would think they should be completely free to return to up position. Am I wrong? The two on my hydro both felt the same after I took out, oiled them and worked them up and down. Both stick down still. They are free, but wont spring back up.
Old 04-03-2011, 03:45 PM
westofb's Avatar
westofb westofb is offline
Might not spring up until the tractor is running and apply hydrallic force to them?
Jeff
Brookfield, MO
________________
Old 04-03-2011, 03:51 PM
They will come back up the first time the tractor is started.
Old 04-03-2011, 07:31 PM
Ok ! I appreciate the help guys!
Old 04-03-2011, 08:50 PM
red211's Avatar
red211 red211 is offline
Mine on the 109 wouldn't go down so I could push it the other day, had to tap them down, very lightly. Fixed the carb and tuned up a few weeks later and started up, tryed to move it out of the basement to run and wouldn't move,valves stuck down. They had been painted and when I tapped them down the crud had them stuck. Pulled both out and worked on them with PB, spray and wipe, after just a few times and working them in and out they were popping out on their own and worked great. Not sure I would use PB with them in the hydro, I hald mine upside down a lot to keep it from possibly running into the valve internals, probably wouldn't hurt, but didn't want to take a chance with the internal seal.
