Old 02-07-2014, 09:55 PM
riesedesperado6170's Avatar
riesedesperado6170 riesedesperado6170 is offline
I hoping to get to build my backhoe this year have PF engineering's plans I already have a kwikway loader but see if the money comes though
Old 02-08-2014, 04:59 PM
BoSox BoSox is offline
Ken what size is your rear tires?
Old 02-08-2014, 05:04 PM
Good job Ken!! My only question, what took you so long to get it set up like that! LOL! I'll say it again, GOOD JOB!
Question:
Where did you get, or what model/brand of backhoe is that?
Also, are you running a PTO driven hydraulic pump, and where is the reservoir?
Old 02-08-2014, 05:29 PM
sawdustdad's Avatar
Nicely done! I like it. But rather than tapering the pins, which would give you a loose fit and potentially a wear issue, I'd weld locating angled tabs on the arms, so that the BH's rings would settle into a "corner" of the angled tabs at just the right location to achieve alignment. That's actually how the QA works on my Kubota BX23 loader. The kubota's QA on the BH has a more complicated arrangement for the upper pins.
Old 02-08-2014, 06:10 PM
I think he meant just putting a taper on the end, so it wouldn't be so hard to start the pin into the hole.
Old 02-08-2014, 06:11 PM
ken6x6's Avatar
ken6x6 ken6x6 is offline
rear tires are the OEM size for the supers 26x12-12 i have Carlise tru powers
127 - 48'' deck + tiller.
1512- 46" GT deck & bagger
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 02-08-2014, 06:15 PM
ken6x6's Avatar
Question:
the backhoe is a Value leader brand. its suppose to be a CAT 1 pto drive. but i modified it to make it work for me.
the hydraulics run off the kwik-way loader pump and the reservoir is in the uprights of the loader.
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
