#21
iphone transfer 1516mmm.jpg iphone transfer 1513mmm.jpg iphone transfer 1510mmm.jpg This is what the clutch looked like. I am going with the idea that the side of the field shouldn't be lifted up like that? Also those bits and pieces where it is breaking up don't look like they will be "healing" up anytime soon either? Here is the result of your test Oak. Nothing. Couldn't get a read off it at all. Even shinned up the plate to make sure I was getting a good connection. Laying the probe on it or just using the point. Same result - nothing. ![]() Sooooo.... I think I am going to get a different clutch from the dealer tomorrow??? Thoughts? I was going to strip the one off the 782, but thought why would I do that and have TWO tractors to put back together? Anyone want to have a beer with me tonight since I won't be moving snow?
Mike Ontario, Canada IH built 982, IH built 782, IH built 782 parts tractor, 100 w/fenders & lights, #4 trailer, 42" front blade, IH 2B tiller, 12" Brinly plow, Brinly cultivator, IH push mower, Sims cab, IH snowthrower, 450 blower. Now everyone wants a Cub! ![]() Beware of the Wife
#22
Looks like you got all the goodness out of that one. You'd think they would have built them to last longer than 40 years. You should see if it's covered under warranty.
#23
Mike, make sure your meter goes to 0 if you touch the red & black leads of the meter together just to make sure your meter is working. If it does make sure that the wire that goes into the clutch isn't broken causing your reading. If all that is good then the clutch is now a paper weight.
#24
#25
Mike measure your shaft to be sure. I just checked a medium flat rate box to Canada is $46! Send me a message with your address if your interested and I will check to see if I can do it cheaper.
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 JD 2155 w/ 175 loader |
| Thread Tools | |
| Display Modes | |
