Old 02-29-2016, 10:54 PM
Mike, you can check the clutch windings with your meter. Set your meter to ohms like I have here, one test lead to the plug and the other to the metal housing of the clutch. Make sure you have a good connection on both leads. This is a rear pto but you should get around 3 to 5 ohms.
Old 03-01-2016, 05:24 AM
Mountain Heritage's Avatar
Oak, what setting do I use on my meter though? I have numbers from 20M down to 200 in the OHM section on the bottom left. I am guessing I set it to 200 since the number will be lower than 200 that I am looking for?
Mike
Ontario, Canada
Now everyone wants a Cub!
Beware of the Wife
Old 03-01-2016, 06:11 AM
Mike:
Use the lowest scale, say 0-200 Ohms.
So by "clutch connector" you are talking right at the clutch itself where the clutch plugs into the wiring harness - right?
Yes.
Will throw something else out there - how do I know or is it possible the clutch itself is shot?
By putting the power directly to the connector by using the Jumper Wire Method, it will either engage or not.
Just curious if a new wiring harness for this tractor might be in order in the future?
A lot of factors to be considered, but it surely wouldn't hurt.
Let's get this PTO to come alive first.
Old 03-01-2016, 04:18 PM
Anyone know if the clutch from a KT-17 and a Mag 20 are the same. Interchangeable? Shaft size the same?
Mike
Ontario, Canada
Beware of the Wife
Old 03-01-2016, 05:33 PM
The PTO clutch from a 782 (KT-17) and a 2072 (M-20) are the same ----> 917-3044
The PTO for a 982 is ----> 917-3012
Old 03-01-2016, 05:39 PM
Sounds good at least I know I can swap them out of needed. I dumped the Onan engine in the 982, have the Mag 20 in it now. Going to try Oak & Roland's diagnostics now. With me luck. If you guys see a large bright light to the North East do not worry it is just me blowing up my 982 due to frustration!
Mike
Ontario, Canada
Beware of the Wife
Old 03-01-2016, 05:41 PM
Mushroom cloud over Ontario
Old 03-01-2016, 06:08 PM
Just about!
Crank shaft pully left or right hand thread? Standing in front of tractor only because I can not get to the back of the tractor for junk!
Mike
Ontario, Canada
Beware of the Wife
Old 03-01-2016, 06:18 PM
Crank shaft pulley left or right hand thread?
What is it that you are trying to do...???
Old 03-01-2016, 06:51 PM
Never mind. Right hand thread!
Did Oak's test - nothing
Did your test Roland - nothing
So off comes the clutch! It has to be the clutch itself. Pictures of it taken. Just need to resize them on computer to let you see what I found. Will tell you one thing - a Mag 20 is so far 100 times easier to break down than an Onan!!!! Omg!
Mike
Ontario, Canada
Beware of the Wife
