Old 05-08-2015, 07:27 PM
mattkarr mattkarr is offline
Default 127 lift bar dimensions for 3 point
Hello I am fabricating half of the parts I need to install the 3 point lift on my 127 and I need the specs on the lift bar
thanks
Old 05-08-2015, 08:42 PM
twoton twoton is offline
Does this help?
http://www.onlycubcadets.net/forum/s...50&postcount=1
Old 05-09-2015, 07:31 AM
Yes it helps but specifically I'm looking for the center to center measurements of the rod that actuate that
Old 05-10-2015, 12:15 AM
gdheck's Avatar
gdheck gdheck is offline
You do realize they are only $35 new right? You also need the plate that the bar connects to too.
Go about 3/4 of the way down on the page.
3 point parts
If you still want to make one, the bar stock is 7/16" thick x 1-3/8" wide x 25-9/16" long. The holes are 24-1/4" apart on center. One hole is 49/64" id. and the other is 41/64" id. The bushing that goes on the bolt and in the large hole is 33/64" id. x 3/4" od. x 1/2" long.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 2072, 2-1864's, 1782, 3 - 42" front blades, 3 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Old 05-10-2015, 01:02 AM
gdheck's Avatar
Actually the lift bar is only $22 here at one of the site sponsors. It's the 4th item down.
Lift bar
Old 05-13-2015, 08:45 AM
mmzullo mmzullo is offline
Here is a drawing of the lift bar. I always make them because I have the metal.
