Old 12-04-2016, 08:45 AM
Green stripe wide frame's Avatar
Green stripe wide frame Green stripe wide frame is offline
Default Another 169 redo
I got this 169 in the summer of 2015 not running. Owner said he went to start it, it popped off, backed fired, and died. It would not restart. He said it was seized.
So I finally did some investigating, I got the motor out. I removed the pan and checked the balance gears all were good. Then removed the flywheel checked for a mouse nest, no issue found there either. Then I removed the head and found that the PO had left the the spark plug off and put side at that. Now the piston is seized. I sprayed some blaster around the piston, loosened it up and remove it.
Though did be able to save it but, after bonding it out and still being able to catch my finger nail on it, is not going to work. Looks like an over haul to the engine is required.
Pics to come
102 soon to be tiller machine
108 mower
73 plow machine
169 soon to be mower
122x2 now parts machines
Parts 129
149 parts
61 "O"
104 job to be determined
Old 12-04-2016, 11:44 AM
Terry C's Avatar
Terry C Terry C is offline
Sounds like a good project. Keep us posted.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 12-04-2016, 01:17 PM
You should proofread......
Old 12-04-2016, 02:09 PM
Wow that's terrible, auto correct on my phone is to blame and me for not proof reading.
"The previous owner left the spark plug out and water had gotten in."
"Thought I would be able to save it. After honing it out found was not going to be able too. Had to much rust where the rings contacted the cylinder."
Thanks for pointing that out
108 mower
73 plow machine
Parts 129
149 parts
61 "O"
Old 12-04-2016, 10:03 PM
The pictures would download of my phone, so here a couple
108 mower
73 plow machine
Parts 129
149 parts
61 "O"
Old 12-04-2016, 10:08 PM
Couple internal pics
108 mower
73 plow machine
Parts 129
149 parts
61 "O"
Old 12-04-2016, 10:13 PM
While I was tearing this engine down I found out it was a kohler short block with only 12 fine.
Oh well.
108 mower
73 plow machine
Parts 129
149 parts
61 "O"
Old 12-04-2016, 10:16 PM
Called in the professionals to help move it to the psi washer
108 mower
73 plow machine
Parts 129
149 parts
61 "O"
Old 12-04-2016, 10:23 PM
All cleaned up
108 mower
73 plow machine
Parts 129
149 parts
61 "O"
Old 12-04-2016, 10:39 PM
Another issue I had with this thing was marking its territory all over my shop, so I drained the hytrans and remove the assembly from the tractor. Then removed the hydro from the diff found the for my seal all wet and a bolt missing from the hydro case.
I'm going to remove the trans assembly from a parts 149 and I think I'm going to use that hydro but the diff from the 169, then I'll transfer over hydralic lift too.
108 mower
73 plow machine
Parts 129
149 parts
61 "O"
