Old 05-06-2019, 10:22 AM
goonpeden goonpeden is offline
Default 18 Magnum PTO
Hello to everyone and hope all is Well!
I have a 2072 that I got as a Basket Case several years ago, re did it in Red 982 fashion, just like the Red Tractors! Installed a 18 Magnum I had and put on Cub Cadet PTO. PTO died Saturday and i would like to install Extreme Outdoor PTO. This engine has a 1 inch crankshaft end for PTO and had Jeff in Pa make me sleeves to adapt the 1 1/4 crank PTO to fit 1 inch crank. Has anyone ever made a PTO swap to an engine with 1 inch crank using the Extreme PTO unit? Thanks! Bill
Old 05-06-2019, 11:47 AM
Was that M-18 out of a Cub Cadet ??
Old 05-06-2019, 12:38 PM
Leadslingingdaddy's Avatar
My M18 had a 1 1/8th Crank.... If you go swapping PTO's make sure you have the correct direction or it will grenade...
Old 05-06-2019, 02:23 PM
Cant say for sure. It was in with a bunch of parts and engines I bought at a flea market. Person I got the stuff from didnt know what is was out of but the price was right on everything. Been running if for a few years with no issues till this PTO died.
Old 05-06-2019, 04:33 PM
CubDieselFan's Avatar
Is the tag with the spec number still on it? Should be around where the fuel pump is mounted.
Old 05-06-2019, 04:37 PM
If the PTO died, then replace it with a like one, that you have. There should be a Vendor (ie: Warner) and a Vendor Part Number. Cross reference to an Xtreme PTO.
Also, get the Kohler "Spec" number from the Model/Serial tag. That will help identify it also.
Old 05-06-2019, 09:21 PM
Also make sure that you MEASURE the Crank, as those cooling tins get swapped along with the engine "spec" numbers/letters after all these years.
Assume nothing!
Old 05-07-2019, 07:34 AM
Could not get any info off the spec label other than 18 HP. I spoke with Extreme and gave them the info from the PTO I took off, it's a Warner 5209-101-055. He could not find a cross to one of their clutches but pointed me to Cub Cadet Specialties and located a new magnet plate that matches the Warner I have. I may have to o that route.
Old 05-07-2019, 08:56 AM
New OEM Warner Front Electric Complete PTO Armature P/N 759-3300 USE 959-3300 or 5209-101-055
Fits:
1050 1204 1210 1211 1535 1541 1710 682 1711 1712 782 784 1810 1811 1812 1860 1862 1872 1882 2072
Old 05-07-2019, 10:19 AM
Thanks Roland! It has not been a good two weeks in my family for pto's! My brother's 125 blew apart last week with a desinigrated bearing and now mine this week! Oh well! At least I know when I'm done its good for a while! Thanks again to all that helped me out! Bill
