I ordered the Ross steering upgrade and put it on. It was easy enough, .but all that "thrust bearing" does is acts like a wide washer. It is a bearing, but it is between a washer at the steering box and the washer and nylon lock nut that comes with it. It is not acting as a bearing, just as a spacer. Am I missing something?...
How about a picture of this "upgrade kit" you bought..??
Picture of Ross upgrade kit
My understanding is that it reduces the drag that would caused by tightening the nut.
That kit consists of:
(1) Nice 605-V Thrust Ball Bearing (1) Steel Washer (1) NyLock Jam Nut Kirk Engineering sells these, and they are a good kit.
So....what does it do?...if you install one you come to realize that the thrust bearing is just serving as a fat washer....it is not between any moving parts at all...it is not acting as a bearing....just takes up space on that bolt that it is on
The kit should allow you to find the "sweet spot" a little easier. They help, I've done it to 3-4 around here, but by itself, they are not a miraculous upgrade if the rest of your steering system is badly worn.
I tried one of them setups, I was not impressed.
I gave it away and installed power steering,---------- that impressed me. It was and is, the single most rewarding modifications I have done to my klub kibbits lawnmowers
Page 5 of this topic:
https://www.onlycubcadets.net/forum/...le+Dick&page=5 is the set up I use. It has been 10 years since I restored this 70. It is one of the more used tractors I own.
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
